Previous Topic: Available Interfaces: Interface InformationNext Topic: Delete Routers from the System
Enable or Disable Interfaces
Interfaces are enabled automatically on the Application Settings page by default. You may want to enable interfaces manually in some cases, such as in the following example scenarios:
Enabling an interface causes the following events to occur immediately:
  1. Open the Available Interfaces page:
    1. Select Administration from the NFA console menu.
    2. Select System: Enable Interfaces in the Administration menu.
      The Available Interfaces page opens.
  2. Click the arrow next to the router that contains the interfaces.
    The view expands to show the interface list. The Enabled status column shows which interfaces are enabled.
  3. Select the check box next to one or more interfaces.
  4. Click one of the following options:
    Data collection for the selected interfaces is enabled or disabled immediately.
