Previous Topic: Customize the PageNext Topic: Available Interfaces: Router Information
Available Interfaces Page
The Available Interfaces page displays information about routers and interfaces. The list of routers and interfaces include the interfaces that have never been enabled and have never been the source of collected data. You can enable or disable interfaces, delete end-of-life routers and their interfaces, and perform some polling troubleshooting.
Router Tasks:
Interface Tasks:
  1. Open the Available Interfaces page:
    1. Select Administration from the NFA console menu.
    2. Select System: Enable Interfaces in the Administration menu.
      The Available Interfaces page opens.
    Use the Available Interfaces page to check capacity, enable or disable interfaces, or delete interfaces or routers.
  2. Use the information and options in the following ways, for example:
