If you delete a router on the Available Interfaces page, the router is deleted from the system entirely. The deletion removes the router, its configuration information, 15-minute (historical) data, interfaces, CVIs, and traps. The deletion also affects any aggregations, views, and reports that previously included the interfaces.
Note: If the interfaces from the deleted router begin to send flow again, a new router appears on the Available Interfaces page. If the program is configured to enable new interfaces automatically, the new router and interfaces also appear on the Active Interfaces page. The new router inherits the current tenant-domain setting of its parent Harvester. Configuration settings for the previous router are lost. If your deployment includes CA Performance Center, the router polls by using the SNMP profiles that are assigned to the Harvester tenant.
The Available Interfaces page opens.
A confirmation message opens.
The following events result:
Copyright © 2014 CA.
