Previous Topic: Available Interfaces: Router InformationNext Topic: Enable or Disable Interfaces
Available Interfaces: Interface Information
The Available Interfaces page includes the following options and information for interfaces.
Enable and Disable
Control whether the interface (or the router and its interfaces) is allowed to send flow to the product, as described in Enable or Disable Interfaces.
Standard Page Options: The standard page options as described in Available Interfaces: Router Information.
Interface Columns
The ifName, ifAlias, Port Name, and vrfName values are present only if the parent router is configured to provide this information to the poller. This information comes from the interfaces database. If you make changes to the corresponding properties on the Active Interfaces page, your changes are not shown here.
Enabled
Setting to let the interface send flow to the product (Yes) or not send flow (No).
License
Status that shows whether the interface has sent flow to the product (Yes) or has never sent flow (No). If the value is 'No,' the system has no records for the interface.
ifIndex
Identifying index value that is automatically assigned to the interface
ifName
Interface name
ifAlias
Interface alias
Port Name
Interface port name
vrfName
Virtual routing and forwarding name
Speed
Maximum data transmission speed for the interface
Last Flow
Most recent date and time that flow was processed. If flow is being collected currently, the Last Flow value is updated every 15 minutes.
