Previous Topic: Search for a Router or InterfaceNext Topic: Delete Routers from the Active Interfaces Page
Edit Router and Interface Details
Edit the properties of a router or interface. For example, you can edit properties to make corrections or to supply missing information.
  1. Open the Active Interfaces page:
    1. Select Administration from the NFA console menu.
    2. Select Interfaces: Physical & Virtual from the Administration menu.
      The Active Interfaces page opens.
  2. Locate the routers, interfaces, or other elements that interest you. To display the contents under a router, click the arrow next to the router name.
  3. Select the check box next to the items you want to edit. You can edit multiple interfaces and CVIs at the same time or edit multiple routers at the same time. You cannot edit a mix of routers, interfaces, and CVIs at the same time.
  4. Click Edit.
    The dialog box opens for editing the selected item or items.
  5. Modify the properties as needed, such as:
    Notes:
  6. Click Save.
    The Edit Router or Edit Interface dialog closes. The changes are shown on the Active Interfaces page.
Notes:
