Use the Search function on the Active Interfaces page to locate routers, interfaces, or CVIs. To search for aggregations, use the Search function on the Interface Aggregations page.
The Active Interfaces page opens.
Note: Do not use wildcards.
The list is filtered to display only the matching entries. If you search for interfaces or CVIs, the search returns a list of routers that contain matching items. When you expand router details, all items appear in the sublists.
To clear the search, click Clear Filter.
Copyright © 2014 CA.
