Previous Topic: Set Up the RoutersNext Topic: Troubleshoot DSA Addition
Add DSAs (Three-Tier Deployment)
Data flows to Harvesters, then to the NFA console and web display.
Applies to: Three-tier architecture in a distributed deployment: NFA console, Harvester, and DSA components installed on separate servers
If you have a three-tier architecture deployment, add one or more DSAs (Data Storage Appliances) to store the 15-minute (historical) data. If you have a standalone system or two-tier architecture, you do not add any DSAs.
We recommend that you add at least one DSA within 30 minutes of starting flow collection. Until you add a DSA to your three-tier deployment, 15-minute data is not available for reports. Reports that show a time range of more than 2 hours do not show any data.
Note: Do not add a DSA instance instead of editing the IP address of a retired DSA. In this case, routers continue to send data to the retired DSA--and that data is not available in reports. If you have to delete a DSA, contact CA Support for assistance.
  1. Open the NFA console, logged in with Administrator rights.
  2. Display the DSA page in the NFA console user interface:
    1. Select Administration from the NFA console menu.
    2. Select System: DSA from the Administration menu.
      The DSA page opens and shows a list of the current DSAs.
  3. Click Add.
    The Add DSA dialog opens.
  4. Enter the IP address for the DSA server.
  5. Click Test Connection.
    A connection test is performed to determine whether the NFA console server can contact the DSA server and can verify that MySQL is installed. If the test succeeds, a "Test success" message opens.
  6. Respond to the test results:
    1. If the Test success message opens, click OK to close it.
    2. If an error message opens, close the error message and respond as described in Troubleshoot DSA Addition.
  7. Once the test completes successfully, click Save in the Add DSA dialog.
    The connection test is performed, followed by a test to locate DSA settings on the target server.
  8. Note the test results:
Notes:
