Previous Topic: Add DSAs (Three-Tier Deployment)Next Topic: Verify That Data Is Received
Troubleshoot DSA Addition
Data flows to Harvesters, then to the NFA console and web display.
Applies to: Three-tier architecture in a distributed deployment: NFA console, Harvester, and DSA components installed on separate servers
If one of the following error messages opens when you click Test Connection or Save in the Add DSA dialog, close the error message and respond as described.
Test Connection Errors
Use the following tips for troubleshooting error messages that may open when you click Test Connection in the Add DSA dialog
Save Errors
Use the following tips for troubleshooting error messages that may open when you click Save in the Add DSA dialog
