Initial Configuration › Configure CA Network Flow Analysis to Work with CA Performance Center › Configure Flow Collection › Set Up the Routers
Set Up the Routers
Enable NetFlow on each CA Network Flow Analysis router by completing the steps in this topic. You can configure routers to export any of the following flow protocols:
- NetFlow v5, v7, v9, and Sampled NetFlow
- sFlow version 5
- IPFIX, Jflow, cFlow, and NetStream flow that complies with the standards for NetFlow v5, v7, or v9
- Back up the current router configuration.
- Configure NetFlow export for each interface individually:
- Set the flow export version.
- Set the flow source IP address. Cisco recommends that you configure a loopback source interface. The IP addresses of non-loopbacked interfaces can change.
- Set the flow destination IP address and set the destination port to 9995.
Note: Ensure that the destination port setting matches the harvesterPort value in the following table: <NFA_install_path>/MySql51/data/harvester/parameter_descriptions.MYD. If you set the destination port to a value other than the default setting, 9995, update the harvesterPort value to match. The port values must match for the Harvester to receive flow data.
- Set the flow expiration timeout to 1 minute.
- Enable flow for each interface.
- NetFlow v5 or v5-compatible flow:
- Monitoring multiple interfaces on a router: Use either all ingress or all egress. Use the same option for all of the interfaces. Ingress and egress values may vary slightly due to routers dropping packets and changing ToS values as traffic travels between interfaces.
- Monitoring a single known interface on a router: Use ingress and egress. This option results in fewer total flows from the router to the Harvester and puts less load on the network and the Harvester.
- NetFlow v9 or v9-compatible flow:
The Harvester identifies and deduplicates multiple flows on a single router, so you can use ingress and egress on multiple interfaces. You may find it most efficient to use this option for two or three interfaces. You have the option to enable ingress and egress across all interfaces, but this configuration may put an unnecessary burden on the Harvester.
- Configure SNMP index persistence on each router that supports this feature.
