Introduction to CA Anomaly Detector › Get Started with CA Anomaly Detector
To get started with CA Anomaly Detector 9.1.3, complete the following tasks:
- If you are upgrading, verify that the existing software version is supported for upgrade: Software Compatibility
- Verify that the installation server has a supported operating system: Operating System
- (Recommended) Verify that the installation server meets the recommended hardware specifications: Hardware Specifications.
- Verify that the installation server meets the prerequisites: Installation and Upgrade Prerequisites.
- Install or upgrade to version 9.1.3 of CA Anomaly Detector and CA Network Flow Analysis:
- Install CA NetQoS Performance Center version 6.1.194 in your environment, if it is not already present, as described in the CA NetQoS Performance Center Installation Guide.
- Configure the firewalls.
- Add CA Anomaly Detector as a data source in the CA NetQoS Performance Center Console: Register with CA NetQoS Performance Center.
- Add CA Network Flow Analysis as a monitored product for CA Anomaly Detector. Optionally, add more products to monitor: Add Products for CA Anomaly Detector to Monitor.
- Enable the monitored products so they supply data to CA Anomaly Detector: Enable the Monitored Products.
- (Optional) Review the sensor configurations and make any necessary changes: Configure the Sensors.
- (Optional) Configure targets for alerts, so that Syslog or SNMP trap messages are sent when alerts are triggered: Configure Alert Targets.
