Previous Topic: Register with CA NetQoS Performance CenterNext Topic: Enable the Monitored Products
Add Products for CA Anomaly Detector to Monitor
Add CA Network Flow Analysis and any other products that you want CA Anomaly Detector to monitor, as described in this topic.
  1. Display the Data Source List page, if it is not open already:
    1. Log in to the CA NetQoS Performance Center Console as a user with administrator privileges, if you are not already logged in.
    2. Select Admin, Data Sources.
      The Data Source List page opens.
  2. Click the name of the CA Anomaly Detector instance that you want to configure with monitored products.
    The Monitored Products page opens.
  3. Click New.
    The New Monitored Product page opens.
  4. Add a CA Network Flow Analysis instance as a monitored product: Specify values for the following options:
  5. Click Save.
    You return to the Monitored Products page, which lists the CA Network Flow Analysis (ReporterAnalyzer) instance. All of the currently configured Harvesters are added as potential data collectors on the Collection Sources page, but the Harvesters are not enabled at this point.
  6. (Optional) Add another monitored product: Specify values for the following options:
  7. Click Save.
    You return to the Monitored Products page, which lists the new instance of CA Network Flow Analysis. CA Anomaly Detector contacts the product to add the collection sources to the Collection Sources page.
  8. Repeat the previous two steps until you have added all of the monitored products that you need.
