Previous Topic: Configure FirewallsNext Topic: Add Products for CA Anomaly Detector to Monitor
Register with CA NetQoS Performance Center
To display CA Anomaly Detector data in reports, you must add CA Anomaly Detector as a data source to CA NetQoS Performance Center, then configure it. Once these tasks are complete, CA Anomaly Detector exports data to CA NetQoS Performance Center, and the data is displayed on the Anomaly Detector report page.
Follow the basic steps in this topic to add CA Anomaly Detector as a data source for CA NetQoS Performance Center. For more information, see the CA NetQoS Performance Center Administrator and User Guide.
  1. Log in to the CA NetQoS Performance Center Console as a user with administrator privileges.
  2. Select Admin, Data Sources.
    The Data Source List page opens.
  3. Click New.
    The Add New Data Source page opens.
  4. Specify values for the following options:
  5. Click Test to verify that the connection to CA Anomaly Detector works.
    If the connection fails, verify that the server name or IP address is accurate for the source type. If the connection fails again, check the following location on the installation server to verify that the appropriate web service is installed:
    http://<hostname>/AnomalyDetector/OdbcService.asmx
    <install_path>\Portal\Integration\AnomalyDetector\OdbcService.asmx, where the default installation directory is C:\CA\NFA.
  6. Click Save when the settings are complete and the connection test has succeeded.
    You return to the Data Source List page, which shows CA Anomaly Detector in the list.
