Previous Topic: Detect a Missing Drive - CA6300Next Topic: Assess and Recover SCSI Disk Corruption
Recover a Failed Drive - CA6300
Applies to CA6300 appliance
Recover a physical drive by using the Disk Utilities option in the RAID Configuration Utility to verify disk media for errors and attempt recovery of bad sectors. Attempt recovery of a physical drive when a RAID array experiences any of the following conditions:
Estimated time to recover a failed drive: 2-3 hours per drive
After attempting disk recovery, rebuild the array. If this is not successful, contact CA Support to request a disk drive replacement.
Important: In the CA Multi-Port Monitor web interface, use the RAID section of the System Status page to verify the logical array number of the failed disk. It can take up to two hours to verify a physical drive.
  1. Restart the appliance.
  2. Press Ctrl+A within 30 seconds to access the RAID Configuration Utilities menu.
    If necessary, restart the appliance again and press Ctrl+A.
    After the BIOS scan completes, select the Disk Utilities option in the RAID Configuration Utility.
    Disk Utilities
  3. Select the disk that you want to recover and press Enter. For the:
    In the following example, the highlighted disk corresponds to Data array Disk1.
    Select Disk
  4. Select Verify Disk Media and press Enter.
    NetQoS--MTP--Verify Disk Media
    It can take up to two hours to verify and recover a physical drive.
More information:
Shut Down or Restart the Appliance
Recover a Failed Drive - CA6000
Applies to CA6000 appliance
Recover a physical drive by using the Drive Utilities to verify disk media for errors and attempt recovery of bad sectors. Attempt recovery of a physical drive when a RAID array experiences any of the following conditions:
  2. Press Ctrl+A within 30 seconds to access the Utilities menu.
  3. After the BIOS scan completes, the Utilities menu for a controller can be reached by selecting #0 for the 5405 and #1 for the 51245:
    2188723
  4. Choose the Disk Utilities option.
  5. Select the disk that you want to recover and press Enter. For the:
    In the following example, the highlighted disk corresponds to Disk 8.
    2190990
  6. Select Verify Disk Media and press Enter.
    2191209
