Applies to CA6000 and CA6300 appliances
Problem: When the appliance starts, a RAID controller BIOS scan indicates the array is degraded with a message similar to the following:
Following Arrays have Missing or Rebuilding or Failed Members and are degraded:
Resolution: Recover a degraded array to avoid data loss. If the status of an array is Degraded, the BIOS prompts you to change the configuration to logically remove the failed or corrupted drive and rebuild the array.
For the CA6000, the System and Data RAID controllers perform BIOS scans when the appliance starts. The terminal display provides diagnostic information after the BIOS scan completes.
For the CA6300, the single RAID controller performs BIOS scans when the appliance starts. The terminal display provides diagnostic information after the BIOS scan completes.
The RAID array status is Degraded when a single disk drive, or segment, has a status of:
The CA Multi-Port Monitor can continue to operate with a degraded RAID array. However, a degraded array should be repaired as soon as possible:
If the array status is Failed, contact CA Support for assistance with reinstalling the operating system and the CA Multi-Port Monitor software.
Array performance can be significantly impacted while an array is in a Degraded state. Keep in mind that while the array rebuilds:
Important: If rebuilding the array does not restore a physical drive to operational condition, replace the drive as soon as possible. Contact CA Support for more information.
