Both primary commands and line commands are allowed on this panel.
If line command I or C, or primary command INS (abbreviation I) is entered, the Define minimum thresholds panel is displayed.
APCBPP21 --- PMA - Define Minimum Consumption Thresholds ---------------------- COMMAND ===> Job name : Job name or generic job name (using '*') '_' is a placeholder for one byte '*' is a generic value used at the end Examples: Job name Comment * all jobs (default) PRJ123* all jobs starting with PRJ123 P_J_2345 all jobs with two wild cards Elapsed time : 00:00 Minutes (format hh:mm) CPU time : 00:00:00 Minutes (format hh:mm:ss) EXCPs : 000000000 No. of EXCPs SRVUs : 000000000 No. of SRVUs total SRVUs CPU : 000000000 No. of SRVUs for CPU SRVUs SRB : 000000000 No. of SRVUs for SRB SRVUs I/O : 000000000 No. of SRVUs I/O SRVUs MSO : 000000000 No. of SRVUs MSO (Main Storage Occupancy) CANCEL: CAN OR PF3
Use this panel to define the job name or job name group and the corresponding thresholds.
Field Name |
Description |
Jobname |
Enter the name of the job for which alert thresholds are defined. Generic notation is allowed by using wildcards _ and *. An underscore _ is a one character placeholder. An asterisk (*) is a placeholder for one or more characters at the end of a name. |
Elapsed time |
Enter the Elapsed time minimum in the format hh:mm. If a job does not reach at least this value, no measurement is generated. |
CPU time |
Enter the CPU time minimum in the format hh:mm:ss. If a job does not reach at least this value, no measurement is generated. |
EXCPs (Execute Channel Program => I/O-Count) |
Enter the EXCP minimum. If a job does not reach at least this value, no measurement is generated. |
SRVUs |
Enter the total SRVU minimum. If a job does not reach at least this value, no measurement is generated. |
SRVUs CPU |
Enter the CPU service units minimum. If a job does not reach at least this value, no measurement is generated. |
SRVUs SRB (Service Request Blocks) |
Enter the SRB service units minimum. If a job does not reach at least this value, no measurement is generated. |
SRVUs I/O |
Enter the I/O service units minimum. If a job does not reach at least this value, no measurement is generated. |
SRVUs MSO (Main Storage Occupancy) |
Enter the MSO service units minimum. If a job does not reach at least this value, no measurement is generated. |
