Administration of the Central Component › Parameter Administration › PMA Thresholds › Absolute Alert Thresholds › Thresholds for Reducing Measurement Activities › Use minimum thresholds during Server runaway alert generation
Define how to consider the minimum consumption alert thresholds in the Server processing (dynamic and step-end runaway check), as follows:
If the option is set to Y, then passing any minimum threshold is sufficient.
- If the option is set to A, then all minimum thresholds relevant to the job must be passed to allow a dynamic runaway or a step-end runaway alert.
This parameter can also be defined/changed in the Server options panel (Min Threshold Alert Generation).
