To view or edit the Central Component parameters, select the Parameters option on the Main Menu. The Parameters Menu is displayed, as shown following.
APCXPP00 --- PMA --- Parameters Menu -------------------------------------- Enter an Option ===> TSO User U1 Print Job JCL Global Parameters G1 Measurement DS processing Global Online Parms G2 CICS and IMS Central Component X1 General Central Component Parameters X2 Scope of Work X3 Standard Programs X4 Standard Procedures X5 Load Module Libraries X6 Job Libraries X7 Procedure Libraries AS MODC Alert suppression Thresholds TA Absolute Alert Thresholds TX Performance Index Alert Thresholds TM Minimum Consumption Thresholds TH Open Alert Thresholds PMA SERVER S1 General PMA SERVER Parameters CICS Feature C1 General CICS Feature Parameters C2 System Control C3 CICS Load Module Libraries C4 CICS SMF Scope Definitions C5 CICS SMF Aggregation Control IMS Feature I1 General IMS Feature Parameters I2 System Control I3 IMS Load Module Libraries I4 IMS INFO Scope Definitions I5 IMS INFO Aggregation Control
If the entire menu does not fit on your screen, press F8 to view the remaining options.
All users need update access authority to the parameter data set.
To use the Parameters Menu, type the selection number in the Enter an Option field. The following list shows the parameter options:
User specific JCL statements to be used for printing reports of all components
Global measurement data set processing
Define global online thresholds for CICS an IMS
General Central Component parameters such aspassword and measurement specifications
Central Component scope of work for Performance Management Assistant and CA Mainframe Application Tuner
Standard program names that allow the Central Component to recognize calls of application programs
Standard procedure names that allow the Central Component to recognize calls of application programs
Load module library names to be examined by the Central Component
Job library names to be examined by the Central Component
Procedure libraries to be examined by the Central Component
Module change alert suppression to be examined by the Alert Handling of the Central Component
Absolute alert threshold values to be used by the alert handling of the Central Component
Performance index alert threshold values
Minimum consumption alert threshold values to be used by the Server and batch SMF processing
Open alert threshold values to be used by the Central Component
General parameters to be used by the server; see Operating the Server.
General parameters to be used by the CICS feature; see Defining Parameters.
General parameters to be used by the IMS feature; see Defining Parameters.
