Previous Topic: Install Previously Created ProductsNext Topic: Specify Enhancements to the Automatic Method
Select Type of Product to Create
After the archived products have been installed, the Product Type dialog appears, prompting you to choose whether you want to create a combined product or a delta product.
combined product
If you select Combined product, the Installing Software dialog appears. The products that you are going to install now are packaged in one SXP product, together with the already installed archived product versions.
delta product
In case of delta products the Analyzing System dialog field is shown, while the Packager is comparing the system state before the reference installation with the current system state after the installation of the archived versions. This data is used later on to reset to the initial state.
The Packager now backs up the configured reference system a second time, so that only the differences from this second backup is later used for creating the SXP archive files. During this time, the system displays the processing status message:
Saving System State
After this, the Installing Software dialog appears to install the complete product. The system is analyzed again, comparing the previous and the current system state.
Finally the Specify Install and Delete Options for Directories dialog appears. Click Continue to complete the reference installation. When the reference system reset phase is enabled (see Reference System Reset), all changes to the reference system are reverted.
You can register the product to the Software Package Library or convert the product into an MSI product.
