Previous Topic: Options for Deleting DirectoriesNext Topic: Specify a Parameter Set
Create a Combined or Delta Product or a Delta Version
To create a combined or delta product or a delta version perform the following steps:
  1. Select the Custom mode using reference installation method on the Create Product Version dialog.
  2. Specify a parameter set (optional)
  3. Install previously created products
  4. Select the product type to create a combined or delta product or a delta version
This is the standard method to create a delta version. Using this method you need not know which changes have been made since the last version.
