Previous Topic: Specify a Parameter SetNext Topic: Select Type of Product to Create
Install Previously Created Products
After you click Custom mode using reference installation on the Create Product Version dialog, the Install Previously Created Products dialog appears. This dialog lets you install the previously archived products that are required to create a combined product, a delta product, or a delta version on your reference system.
If you select an archived version of a delta product, the Packager automatically installs the version you selected including all predecessor versions, and the product on which it is based.
Important! Manual entries that you make in the SXP archive files of the archived products (details on user rights, pre- or post-programs, and so on) are not included in the product to be packaged.
Select a version from the list and click Install. You can install any of the versions listed. However, before continuing, you must account for any dependencies the version may have, on any other products that are included in the list. For example, if the version you want to install requires a software product named XYZ 5000 as an installation prerequisite, you must make sure that XYZ 5000 is installed on the reference system before continuing.
During the installation of the archive version, you may be asked to log off and on again or to restart the computer, if changes have been made to the system. In this situation, the Packager for Windows ensures that when the system restarts, it resumes the packaging process from the exact point at which it was stopped.
Important! When previously archived products are installed, the original.sxp archive file is not evaluated, the pre- and post-programs are not executed, and an installation with the original setup file is not performed.
