Using the Packager for Windows › Parameter Archive › Enter and Edit Client Parameters
You can use the following methods to enter parameters for all target computers:
- Enter all required parameters under the default icon. To do this, select the default object in the right pane, and then create the individual entries, using either of the following ways:
- From the Packager main menu, select Edit, Parameter, Add
- Right-click the default object to display the shortcut menu and select Add parameter.
- Move PC objects into the same group when you want to set the same parameter settings for all of them at one time. After you move the PCs to the same group, you can set the necessary group parameters (see Group Objects).
- Move PCs that have or will have PC-specific parameters to the bottom of the archive tree. Select and set the values for each one individually (see PC Objects).
You must specify parameters for the default object before you specify them for the Group objects or PC objects. Therefore, you must first specify the type, range of values, default value, and description for each parameter in the default object. You can then specify parameter values for either Group objects or PC objects.
Information about naming standards can be found under Parameter Names.
If a large number of parameters need to be entered, you can use tools for automatic parameter generation.
