Previous Topic: Group ObjectsNext Topic: Client Parameter Files and Parameter Format
PC Objects
PC objects contain all parameters, some of which may deviate from the parameters of the closest object hierarchically (default or group). A PC object can be located either directly below the default object or at the third level of the tree.
To create a PC object
  1. Select the default object
  2. Right-click the default object and select Add PC from the shortcut menu.
  3. Name the PC object according to your site standards.
  4. Right-click the PC object to display two shortcut options:
    Delete PC
    Removes a PC object from the second or third level of the tree.
    Create parameter product
    Passes the client parameters as an SXP product in the product archive.
To administer parameters for a PC object
  1. Select the PC object in the left pane.
  2. Right-click the PC object and select one of the following options from the shortcut menu:
    Edit parameter
    Modifies the parameter value for the selected PC within the value range.
To move a PC object from one group to another
  2. Drag and drop the PC object onto a group object.
All parameter values for the group are applied to any PC you move to the group, except for PC-specific parameter values.
