The group object contains all parameters for a group of PCs and is located at the second level of the tree. Create group objects when you want to assign parameter values for the group that are different than the default values. Generally, create the group first and add the PC objects to it. Then, modify the necessary parameter values for the group.
To create a group object
To administer a computer group
Deletes a group object from the second level of the tree.
Creates a PC object in the third level of the tree.
Passes the client parameters as an SXP product in the product archive.
Important! Each computer that you create can belong to only one group.
To administer parameters for a group
Modifies the parameter value within the defined range of values. The values also apply for lower level PCs, if you have not set a different value for this parameter.
Group-specific values take precedence over default values, and computer-specific values take precedence over both default values and group-specific values.
