Previous Topic: Internal ParametersNext Topic: Enter and Edit Client Parameters
External Parameters
External parameters are defined after the initial packaging process has completed.
External parameters are optional but can be useful in customized installations. If you want to use external parameters, package and register them before distributing them to the target computers.
If you are specifying an external parameter, never start its name with the letters Sxp, as this prefix is reserved for the names of internal parameters.
Many administrators work with one parameter product that stores the parameters of all products. However, you can define several different versions of parameter products, if needed.
Note: If an SXP product has an internal dependency on a parameter product, the parameter product must be installed on the target computers before the SXP product is installed.
