Previous Topic: Client Parameters WindowNext Topic: Group Objects
Default Object
The default object is located at the top level of the tree and contains all parameters. Right-click the default object to display the three shortcut menu options:
Add Group
Creates a group object that inherits the default values.
Add PC
Creates a PC object that inherits the parameter values of the closest object hierarchically in the tree (default or group).
Create parameter product
Passes on the client parameters as an SXP product in the product archive.
To administer default parameters
  1. Select the default object in the left pane.
  2. Select a specific parameter in the right pane
  3. Right-click the parameter and select one of the following options from the context menu:
    Add parameter
    Creates a parameter in the default object.
    Edit parameter
    Modifies the values, range, and the description of a parameter.
    Delete parameter
    Deletes a parameter from the default object.
    Passes the client parameters as an SXP product in the product archive.
You must first assign default values, and then, if needed, assign either group-specific or computer-specific deviations from the defaults. Group-specific values take precedence over default values, and computer-specific values take precedence over both default values and group-specific values.
Important! If you delete a parameter from the default section, that parameter is no longer available for any new group or PC objects. In addition, the deleted parameter is removed from any existing group and PC objects.
