Previous Topic: Automatic Parameter GenerationNext Topic: Default Object
Client Parameters Window
To edit client parameters, select Edit, Client parameters from the Packager main menu. The Client Parameters window appears, where you can define all parameters, for any SXP product, with values specific to each individual PC in your system (PC-specific values). All of the parameters contain default values, from the default object, that can optionally be overwritten with either group-specific values or computer-specific values.
A sample Client Parameters window is shown following:
Screenshot of a sample Client Parameters window
The Client Parameters window consists of two panes.
The following icons are used in the left pane of the Client Parameters window:
Icon representing a Default object for parameters
Indicates the default object (yellow symbol). The default object contains all parameters. Initially, there are no parameters; you must create them.
Icon representing a Group object for parameters
Indicates a group object (red symbol). A group object contains parameters for a specific group of target computers that deviate from the default object.
Initially, there are no group objects; you must create them. When you create a group object, it inherits all default parameters. You can change the parameter values, but not their type or length.
Icon representing a PC object for parameters
Indicates a PC object (green symbol). A PC object contains parameters for a specific target computer that deviate from either the default object, the PC group to which the computer belongs, or both. Each target computer that requires individual parameters requires its own entry.
Initially, the PC object Admin represents the Packager. When you create a PC object, it inherits all parameters from the group object or default object from which it was created. You can change the values of the parameters, but not their type or length.
The following icons are used in the right pane of the Client Parameters window:
Icon for default parameter value
Indicates a default parameter value.
Icon for a group-specific parameter value
Indicates a group-specific parameter value.
Icon for a PC-specific parameter value
Indicates a PC-specific parameter value.
You must first assign default values, and then, if needed, assign either group-specific or computer-specific deviations from the defaults. Group-specific values take precedence over default values, and computer-specific values take precedence over both default values and group-specific values.
