Previous Topic: Create a Combined or Delta Product or a Delta VersionNext Topic: Install Previously Created Products
Specify a Parameter Set
If a product to be installed in the step "Install previously created products" uses client specified parameters, these external parameters are substituted by one of the following methods:
The temporary file param.ini is recreated every time by the Packager and cannot be used for substituting parameters manually. Use the Client Parameter editor for the Packager PC instead.
