Previous Topic: Create New User DialogNext Topic: Name Not Found Dialog
Add Users Dialog
If your current security provider is Unified, the Add Users dialog appears when you click the Add button on the Users tab of the DSM Properties - Remote Control dialog. Use this dialog to add new users who can connect to your computer.
Note: This same dialog is used to add new users or user groups to an address book and to assign administrative users to a specific domain manager.
This dialog contains the following fields:
Repository
Displays the name of the host or domain manager's repository or domain, as appropriate.
User or Group Name
Defines the name of the user or group that you want to assign to the address book (or to a domain manager). Multiple users or user groups from the same domain or directory can be entered using semicolons to separate names.
Alternatively, use the Browse button to locate the user or group.
Note: If you mistype a name or enter one that is invalid, the Name Not Found Dialog appears, letting you edit the incorrect entry.
Users to Add
Displays all users added to the selected domain. Includes user name, full name (if available), and repository information for each user.
This dialog contains the following buttons:
Browse
Selects the Windows domain, directory, or certificate store that you want to use when adding new users or user groups defined to a specified repository.
The Browse Repositories dialog or the (Browse) Users dialog appears, displaying either a list of available domains and directories or users.
Add
Adds users from the selected domain as users on the domain manager.
Remove
Deletes the selected user or user group from a list of those with access to the host (or to the domain manager, if appropriate).
More information:
DSM Properties - Remote Control Dialog
Delete Users
