The Name Not Found dialog lets you edit the name of a user, user group, or repository if you have mistyped the name or entered one that is not valid, that is, cannot be found in the specified repository.
This dialog contains the following fields:
If selected, specifies that the information about an object—user, user group, or repository—be corrected and that another search of the specified repository be performed. If the subsequent search is successful, the Name Not Found dialog closes and the user, user group, or repository is added to the list of users or repositories.
Default: True
Displays the name of the specified repository or domain.
Defines the name of the user or user group that you want to either add or remove, depending on which option is selected.
If selected, specifies that the named object—user, user group, or repository—be removed from the list of users or repositories.
Default: False
This dialog contains the following button:
Selects the Windows domain, directory, or certificate store that you want to use when adding new users or user groups defined to a specified repository.
The Browse Repositories dialog or the (Browse) Users dialog appears, displaying either a list of available domains and directories or users.
