Previous Topic: Add New UsersNext Topic: Add Users Dialog
Create New User Dialog
If your current security provider is Local, the Create New User dialog appears when you click the Add button from the Users tab. This dialog lets you add new users who can connect to your computer.
This dialog contains the following fields:
User Name
Defines the user name. This can be of any length (except zero) and be composed of letters, numbers, and characters used in punctuation.
Note: You cannot use the "\" and "/" characters.
Full Name
(Optional) Defines the full name of the user.
Notes
(Optional) Provides an area where you can enter any noteworthy information for this user.
Password
Defines the user password.
Confirm Password
Confirms that the user password has been entered correctly.
This dialog contains the following buttons:
Change Password
Invokes the Change User Password dialog, letting you update the user's password information.
Create
Creates a new user and adds the user description to the list in the Users tab.
