The DSM Properties - Remote Control dialog lets you configure the host computer. This dialog is dynamic and may contain any or all the following tabs based on options selected during installation.
Note: Options available in this dialog may not be configurable by the host user if the host is running in a centrally managed environment, wherein remote control configuration policies are set by the IT administrator using policy. Properties are dimmed if they are managed centrally or if you do not have the rights to edit them (because you are not the administrator of the computer).
This dialog contains the following tabs:
