The Set Master Password dialog lets you set the master password for any security provider or change a previously set master password.
This dialog contains the following fields:
Specifies the master password currently in use.
Specifies the new master password.
Note: Passwords must be non-blank and cannot be less than six characters. You can combine letters, numbers, and characters used in punctuation.
Requires you to reenter the new master password for confirmation purposes.
