Use the command line if you are updating multiple OS images using a batch script.
Note: If you have deployed the same OS image on multiple boot servers, update the image and create a corresponding update SD package on the Image Prepare System first. You can then deploy the updated SD package to all the other boot servers in the domain using a software delivery job.
CreatOSImage -i <imagename> -e
The command updates the existing image with the new templates.
registerOSImage -i <image name> -s <manager> -e
The command updates the image on the domain manager specified with the -s parameter.
registerOSImage -i <image name> -s <manager> -e -l
The command creates an SD package with the updated OS image. The updated package has "-update" appended to the original package name. The updated package can be used to update the OS image on remote boot servers using an SD job with the Update Image on Boot Server procedure.
Execute the following command to update the parameter definitions of the image:
Important! You may lose the customized parameter definitions if they have been updated or deleted in the new template.
registerOSImage -i <image name> -s <manager> -e -b
The command updates the parameter definitions of the OS image in the MDB. The updates include changes to the default values, new, updated, or deleted parameter definitions.
The OS image is now updated in the domain manager and in the boot servers.
You can create an OS image by using the corresponding wizards in DSM Explorer or the corresponding commands from the CLI.
The image is created and is available to the Image Prepare System.
You can now register the OS image.
For RHEL6 OS Image Creation:
When you use the Local or Network folder option in the OS image creation, ensure that the accessed folder has the following steps:
The version of the RPM package changes with RHEL6 updates.
The directory structure is in the following format:
SharedFolder\cd1.iso
SharedFolder \images
SharedFolder \ Packages\ Red_Hat_Enterprise_Linux-Release_Notes-6-en-US-3-7.el6.noarch.rpm
SharedFolder \.discinfo
When you use Central NFS Server in the OS installation ensure that:
NFSShare\cd1.iso
NFSShare\images\ install.img
NFSShare\images\ product.img
Note: When registering, select the option to stage the SD deployment image for distribution to one or more boot servers using Software Delivery.
Create an OS Image:
Use the following command to create a new OS Image:
createosimage -i <image Name> -o <OS Type> -s <OSpath>
The following example creates a new RedHat x64 OS image RH55x64 and reads the installation files from a folder.
createosimage -i RH55x64 -o RH5XPE -s f:\redhat_55_x65_files
Register this image with the DSM domain to be made available for deployment. Use the OS image registration wizard or the command line to register the image. When registering, you can opt to create an SD deployment image for distribution to one or more boot-servers using Software Delivery.
Register the OS Image:
Use the following command to register the boot image:
RegisterOSImage -s <manager> -i <imagename> | -w <directory> [-b] [-l] [-t] [-e] [-n <name>] [-v <version>] [-c <comment>] [-u <user> -p <password> -d <domain>]
To perform an unattended installation of the OS, activate the OS deployment on the target computer.
The OS Installation wizard opens.
An OS deployment job is created and the deployment status is displayed in the Computers and Users, All Computers, Group Details, and OS Installations node.
OS is deployed using the Linux-based boot image.
Note: The disk (either local or remote) being used for OS deployment must be the first disk in the boot sequence among all the available bootable disks (disks holding any bootable OS or bootable media).
CA ITCM supports the installation of RHEL 5.x and 6.x OS on the first local disk only and this disk must be the first disk in the BIOS boot sequence.
In a SAN environment, this task involves assigning a Disk Identifier (SANID) to the OS image so that it can identify the SAN disk on which deployment is planned.
Understand the SANID Boot Parameter
The SANID boot parameter is added to the RHEL6, ESXi 4.1 and ESXi 5.1OS images to identify a specific target related to a particular SAN logical unit number (LUN) or Disk. This provision ensures that the specified LUN or Disk is explicitly selected. SANID boot parameter holds the identifier value that is associated with the specified Disk or LUN like World Wide Name (WWN) or World Wide Identifier (WWID) based on Network Address Authority (NAA) format.
The supported formats (with example values) for SANID are:
value
naa.60a9800064762f34694a6e3651697759 60a9800064762f34694a6e3651697759
For backward compatibility, support for the SANID value in the attribute=value format is available as shown below:
TargetLUN=naa.60a9800064762f34694a6e3651697759
The support for providing the SANID parameter using EUI format is dropped from this release.
When the SANID value is empty, the ESXi installation scripts use the first available local disk for the installation per the existing behavior. Also, this disk must be the first disk in the BIOS boot sequence.
After the OS deployment is started, system administrator can verify the status of the job from the job status.
The job status depends on the following two parameters:
SignalCompletion signals the completion of the OS installation in addition to the InstallAgent parameter.
CA ITCM agent installation is not supported on VMware ESXi 4.1, VMware ESXi 5.1, and Citrix XenServer hypervisors. Hence, InstallAgent parameter is set to No by default for these operating systems.
The SignalCompletion and InstallAgent parameters have the following use cases:
InstallAgent Value |
SignalCompletion Value |
Status of the OS Installation Job |
Yes |
Yes |
Job is marked as current after successful OS installation. |
Yes |
No |
Job is marked as current on the OS that have agent support in CA ITCM. For other OS like hypervisors, the job remains in installing state. |
No |
Yes |
Job is marked as current after the successful OS installation. |
No |
No |
Job is marked as current after the Boot Image downloaded. |
