The description file for a boot image is stored in the <image store>\images\dosboot\undi\<boot_image_name>.
The description file for a boot image contains a [BootImage] section with the following parameters:
Defines the features or properties of the boot image. The value of this property can contain a comma-separated list of key words.
Note: The key words are case-sensitive.
Following tables provides the list of key words that you can use with this parameter:
Keyword |
Definition |
F140-2 |
Specifies that the image can accept parameters in FIPS-compliant encryption only |
DosTftp |
Specifies that the image is DOS-based and supports installation through TFTP mode |
DosLm |
Specifies that the image is DOS-based and supports installation through share mode Note: This key word cannot be combined with the key word F140-2 as DOS images are not FIPS-compliant. |
PeTftp |
Specifies that the image is WinPE-based and supports installation through TFTP mode |
PeLm |
Specifies that the image is WinPE-based and supports installation through share mode |
Pe2Lm |
Specifies that the image is WinPE20-based or WinPE30-based and supports installation through share mode |
Pe64Tftp |
Specifies that the image is WinPEx64-based and supports installation through TFTP mode |
Pe64Lm |
Specifies that the image is WinPEx64-based and supports installation through share mode |
DosLmT |
Specifies that the image is DOS-based and uses TFTP in share mode. When CA ITCM is operating in FIPS-only mode, use this key word for Linux OS installations that use DOS‑based boot images |
Specifies the type of the boot image. Following are valid values:
For LinuxPEx64, See Create and Register a Boot Image using DSM Explorer
Specifies the directory that contains boot image files.
Specifies the network loader for the boot image, which is stored in the directory specified in Bootimagedir.
Specifies that the boot server must switch to the next boot image or boothd if the specified file is downloaded from Bootimagedir.
Sample winpe2.2 file:
[BootImage]
Imageflags Boottype=WinPE2 Bootimagedir=winpe2.2 Bootloader=pxeboot.n12 Switchfile=winpe.wim
