The default.ini describes the OS Installation Manager parameters used in an OS image and the default settings for these parameters. The file is a UTF-8 coded file and should be edited with UTF-8 enabled editors only e.g. Notepad. The file has a .ini file structure. The file shows the following sections:
The code page 3 indicates that this file is a UTF-8 file.
This section contains the default settings for the parameters. The entries use the following format:
parameterName >= defaultValue
This section lists a number of names that should not be used as OS Installation Manager parameter names. The entries of the section use the following format:
name=parameter
