Modules to be traced Policy Group
The Modules to be traced policy group contains the following policies for the modules used by the Software Management Installer program. You can modify policy parameter values by double-clicking a policy to display the Setting Properties dialog.
Specifies the SM Installer trace level. Valid values are as follows:
Traces error only.
Provides a full trace, being available locally and as job output.
Provides a full trace, but the information is not provided as job output.
Default: error, <locally managed>
