Memory limits Policy Group
The Memory limits policy group contains the following policies for the buffers used by the Software Management Installer program. You can modify policy parameter values by double-clicking a policy to display the Setting Properties dialog.
Specifies the buffer size for the file paths of the parameter files.
Default: 1000, <locally managed>
Specifies the buffer size for the section names of the parameter files.
Default: 300, <locally managed>
