Previous Topic: Modules to be traced Policy GroupNext Topic: Shell Policy Group
Protocol settings Policy Group
The Protocol settings policy group contains the following policies for log entries. You can modify policy parameter values by double-clicking a policy to display the Setting Properties dialog.
Directory
Specifies the name of the log directory. A log file is created in this directory for every install or uninstall under the name PC Name.nnn, where PC Name is the name of the PC in the network and nnn is the log number. The log number is incremented by 1 before a log file is created, and reset to 0 if the Maximum number of protocol files policy value is exceeded, that is, if the previous log file is overwritten.
Default: empty, <locally managed>
Specifies the highest possible log number.
Default: 10, <locally managed>
