Previous Topic: System Tray Policy GroupNext Topic: Directories Policy Group
Wake-On-LAN Policy Group
The Wake-On-LAN policy group lets you set policies for remotely and automatically powering up physical computers in your enterprise. You can modify policy parameter values by double-clicking a policy to display the Setting Properties dialog.
The Wake-On-LAN policy group contains the following policies:
WOL: Broadcast
Indicates the type of wake-on-LAN (WOL) datagram used to wake physical computers. Valid values are Unicast, Broadcast, and Broadcast + Unicast.
Default: Broadcast + Unicast
Enable guest nets
Indicates whether WOL datagrams can be sent to guest networks in addition to the original network where the computer is registered.
Default: False
Guest net address 1 - Guest net address 5
If Enable guest nets is set to True, specifies the network address of each guest net. Up to five guest nets can be specified.
Guest net mask 1 - Guest net mask 5
If Enable guest nets is set to True, specifies the subnet mask of each guest net. Up to five net masks can be specified.
WOL: Port
Specifies the UDP port to which WOL datagrams are to be sent.
Default: 7
