Directories Policy Group
The Directories policy group contains the following policies for common component directories. You can modify policy parameter values by double-clicking a policy to display the Setting Properties dialog.
Specifies the file location path for the XML logs generated by the Default Directory Synchronization Job (cmDirEngJob).
Note: For more information about this job, see the Directory Integration section of the DSM Explorer Help.
Default: <locally managed>
The Directories policy group also contains the following policy group subfolder:
Options Policy Group
