Previous Topic: Configure Automatic Powersave on ComputersNext Topic: Wake-On-LAN Policy Group
System Tray Policy Group
The System Tray policy group contains the following CAF policies. You can modify policy parameter values by double-clicking a policy to display the Setting Properties dialog.
System Tray: Display commands
Indicates whether the DSM Framework Service commands are displayed.
Default: True
System Tray: Hidden
Indicates whether the system tray applet is hidden. If True, the system tray does not show any icons.
Note: If you modify the policy value, this change takes effect at the next login.
Default: False
System Tray: Visible
Indicates whether the notification area icon is displayed. If True, only the DSM Service icon is hidden. The product-specific plug-in icons are shown in the notification area as separate icons.
Default: True
Note: To manually start the system tray, use one of the following commands: cfsystray or cfsystray show. For more information, type <command> /? at the command prompt.
