Previous Topic: General Policy Group (Software Management)Next Topic: Memory limits Policy Group
Logon Shield Policy Group
The Logon Shield policy group specifies Logon Shield options for Microsoft Windows agents. You can modify policy parameter values using either the Logon Shield configuration view or the Setting Properties dialog.
Apply Windows security options
Windows Vista only: If enabled, some Windows policy security options are controlled by Logon Shield. They are set by Logon Shield in the scope of installing, activating, or uninstalling the Logon Shield.
Note: If you prefer controlling these security options using Windows group policies, disable this policy. Otherwise, both configuration systems would interfere with each other and cause unpredictable results.
Default: Enabled
Disable Ctrl+Alt+Del
Indicates whether pressing CTRL+ALT+DEL is required before a user can log on. If this policy is enabled, a user is required to press CTRL+ALT+DEL before logging on to Windows. For use with Logon Shield, it is highly recommended that this policy be disabled.
Default: Disabled
Hide fast user switching
Determines whether a user can use fast user switching. When this policy is enabled, it is not possible to switch users without logging off. For use with Logon Shield, it is highly recommended that this policy be enabled.
Default: Enabled
Maximum blocking time
Specifies a period of time after which the system will be unblocked. This policy defines the maximum time in minutes for which logon will be prevented, thereby avoiding permanent blocking of a system.
Default: 120, <locally managed>
Mode of operation
Determines the log-on condition under which software delivery jobs are executed and the installation status of the Logon Shield. Valid modes of operation are as follows:
Logon Shield not installed
Indicates that the Logon Shield provider and -filter COM modules are unregistered on Windows Vista. On earlier versions of Windows, the sxpgina.dll is uninstalled.
No restriction on job execution
Indicates that Logon Shield is not activated when a software delivery job executes.
Force user to log off before job executes
Forces the user to log off when a software delivery job is waiting to be executed. The Logon Shield is activated during job execution.
Apply job-defined condition
As a condition of a previously defined software delivery job, forces the user to log off when the job is waiting to be executed.
Wait until user logs off before job executes
Indicates that software delivery jobs are only executed when a user is logged off. However, the user is not asked to log off when a software delivery job is pending. The Logon Shield is active during job execution.
Wait until user logs on before job executes
Indicates that pending software delivery jobs are only executed when a user is logged on.
Default: Logon Shield not installed, <locally managed>
Shutdown without log on
Determines whether a computer can be shut down without having to log on to Windows. When this policy is disabled, users must be able to log on to the computer successfully and have the "Shut down the system" user right before they can perform a system shutdown. For use with Logon Shield, it is highly recommended that this policy be disabled.
Default: Disabled
More information:
How to Use the Logon Shield Configuration View
How to Use Configuration Views
