Use the Connection Addresses dialog to modify a connection address for a specified remote control computer.
This dialog contains the following fields:
Displays the network protocol type specified for a connection address.
Specifies the computer name or the primary network address to be used to connect to a remote computer.
Indicates whether an address is reported by the host or not. If Yes, the reported address cannot be modified, as only user-defined addresses can be modified.
Displays tips for selecting options or entering information in fields or dialogs.
This dialog contains the following buttons:
Invokes the Protocol/Address dialog, which lets you add a new address for connecting to the remote computer. You may enter more than one for each computer.
Invokes the Protocol/Address dialog, which lets you change the existing details of a connection address for a remote computer.
Removes the address entry from the list of connections.
