You can record an active session at any time.
To record an active session
All currently connected remote control sessions are displayed in the DSM Remote Control tree and the Sessions pane.
The Save As dialog displays the file name assigned to the session and the default location assigned for storage.
Remote Control begins recording the session and does not stop until you click Stop or terminate the session.
Alternatively, you can also select the Record Session option in the Viewer tab of the Connection Settings dialog. For more information, see the Remote Control Viewer Help.
