The Active Replays pane displays all the recordings that are currently being played back. This pane lists each of the active replays. From the pane, you can close individual or all active replays.
This pane contains the following fields:
Displays pane-specific tips for selecting options or entering information.
Identifies the name of the recorded session. By default, this name is assigned by Remote Control and is configured using the computer name, date, and time in the format hostname_yyyymmdd_HHmm. It is appended with the .urc extension.
Example: TESTPC_20080914_1200.urc
Provides you with the current status of the active replay you selected. Available status codes match those of the Remote Control replayer controls in the Remote Control toolbar (such as playing, paused, slow playing, and so on).
Displays the time (in minutes and seconds) remaining for replaying the active session.
