Previous Topic: Recently Recorded Sessions PaneNext Topic: Active Replays Pane
Recently Replayed Sessions Pane
Use the Recently Replayed Sessions pane to view sessions that have been recently replayed. The last 10 replayed sessions are listed in this pane. From this pane, you can open and delete replayed sessions, remove shortcuts, and export a recorded session file to video format.
This pane contains the following informational fields:
Information
Displays pane-specific tips for selecting options or entering information.
Name
Identifies the name of the recorded session. By default, this name is assigned by Remote Control and is configured using the computer name, date, and time in the format hostname_yyyymmdd_HHmm. It is appended with the .urc extension.
Example: TESTPC_20080914_1200.urc
Duration
Defines the length of the recorded session.
Size
Defines the size of the recorded session file.
Compressed
Indicates whether the recorded session is compressed.
Compression Ratio
Indicates the compression ratio of the recorded session file.
