Previous Topic: Launch the Replayer from Windows ExplorerNext Topic: Recently Replayed Sessions Pane
Recently Recorded Sessions Pane
The Recently Recorded Sessions pane contains a listing of the last 10 sessions recorded. From this pane, you can open and delete recently recorded sessions, remove shortcuts, and export a recorded session file to video format.
This pane contains the following informational fields when viewed in Details mode:
Information
Displays pane-specific tips for selecting options or entering information.
Name
Identifies the name of the recorded session. By default, this name is assigned by Remote Control and is configured using the computer name, date, and time in the format hostname_yyyymmdd_HHmm. It is appended with the .urc extension.
Example: TESTPC_20080914_1200.urc
Duration
Defines the length of the recorded session.
Size
Defines the size of the recorded session file.
Compressed
Indicates whether the recorded session is compressed.
Compression Ratio
Indicates the compression ratio of the recorded session file.
