When the viewer window is smaller than the host's display, your screen is clipped, and you see only part of the host display at a time. You can, however, scroll the host screen or choose another scroll mode, such as Auto Pan or Shrink/Scale to Fit.
When the viewer screen resolution is higher than the host screen, the host screen appears in a window unless Scale to Fit is selected.
