Previous Topic: My Sessions PaneNext Topic: Session Menu Options
Quick Connect Sessions
When you click Quick Connect under the My Sessions node or select the Tools, Quick Connect menu command, the Connection Settings dialog appears in the right pane.
This version of the Connection Settings dialog has no Connection field. Instead it has a Protocol drop-down list and an Address field. When you enter the required data and click Connect, the name of the Quick Connect session node changes to that which was specified in the Address field.
More information:
Connection Settings Dialog
