Previous Topic: Delete a Favorite ComputerNext Topic: View Recently Used Computers
Recently Used Folder
The Recently Used folder in the DSM Remote Control tree contains a list of the most recent computers to which you connected. This feature lets you reconnect to a recently used computer. To set the number of connections for the system to remember and display in the corresponding pane, right-click the folder and choose a number between 1 and 100 from the Properties of Recently Used dialog.
Note: The Recently Used folder does not list the same computer more than once no matter how many times you have connected to it recently.
Right-clicking a computer in the Name field in the corresponding Recently Used pane displays several menu options.
More information:
Viewer Pane
